Cowden, IL
5/25/2021 4:13pm
I
I had a kid bring me this cr125 to work on that was idling high and running irratic. I checked for air leaks, adjusted the air screw, all tge regular stuff. Then i pulled the slide out and found the rear side is broken off, kinda looks like it has been eatin away. Have any of you seen this before?
Honda offer a 4.0 slide that is a little still than the Yamaha 4.25, but again is a direct drop in. With either of the 4.25 and 4.0 slides you also have the ability to cut them leaner into a 4.5 or leaner.
https://www.partzilla.com/product/honda/16022-KSR-734?ref=a2dd5c8e0915e…
JD jetting offers a 5.0 slide that will be leaner than the 4.5 slide, but will need the port fill to work with the TPS. I fill the port with paper and finish the top 1/2 inch or so off with JB Weld.
From rich to lean, it would be ---4.0, 4.25, 4.5, 5.0, 5.5, 5.75.....
Post a reply to: 2004 CR125 broken carb slide
