Lamont, IA
My 03 yz250f starts hard even with the choke on. It will take me anywhere from 20 to 30 kicks to fire it up. Once it's running, I cant turn the choke off and I cant give it any kind of throttle. Once it runs for about 5 mins it will allow me to give it throttle and turn the choke off, however, when the rpms drop it just dies. I've taken the carb off and only cleaned the float bowl and the few jets I could get to. Please help me with this!!! 🥺
You also need to check the valves.
They are suggesting to check the valves because hard starting on a four stroke, especially a older one like yours is normally due to tight valve clearance. You should be checking them every 20-30hrs. It sounds fairly neglected, I’d toss a piston in while you’re working on it.
Post a reply to: 2003 yz250f wont run with out choke
