- Pick trends
- Create a private league
- And more!
Does the old rubber glove over the uncapped fill port with the bike running trick to see if theres any kind of vacuum or pressure build up occuring apply to 2 stroke motorcycles the same way it does with PCV valve equipped automobile engines?
I have the same bike and can help you out if you find something you suspect ....IE the glove inflates on your end etc. to see if I get the same result. I've never had that issue so let me know if there's anything you'd like me to check or try if it will help you out at all.
Post a reply to: 2003 cr250 leaking trans fluid from fill plug
