Springdale, AR
Took the bike out this weekend and spun a few laps. About 20 minutes in, I hear a hissing noise very similar to what I would expect air leaking out of the fork or shock to sound like. I pull off and check everything over real quickly and see nothing glaring. I ride some more and don't hear it again for another 5-10 laps. I can't find anything that sticks out to me as a "shade tree" mechanic that would point to an issue. I can cycle the suspension with my body weight in the garage and get no noises. I don't see any leaks anywhere and nothing appears to be broken. Tires are holding air just fine as well. I'm baffled and wanted to ask around to see if anyone else had experienced anything like this before or might have any ideas as to what is happening. I know it's sort of an impossible question to answer without actually touching the bike, but thought it might be worth a shot. Thanks in advance for any help
It could be one of the o-rings on the inner chamber. These chambers need to be completely full of oil and then pumped to remove the excess when you reassemble. If the seal has gone, it might have some air inside and potentially that is what you can hear.
Post a reply to: 2003 RM250 hissing noise
