11/8/2018 3:28am
Hi everyone,
I have been researching carb options for my dad's 2003 CR250R as we haven't been able to get the stock TMX to run great. We've had the bike for a few years and I found it to be jetted pretty well as I ride lots of wide open throttle, but now that my dad is riding it using more low end and mid range he finds it lacking.
We have settled on the 38MM PWK Air Striker from Keihin based on the reviews from the forum and I found Digger's recommendation for a Suzuki NEDW needle in #3 with a 42 pilot and 172 main. I am in Sault Ste Marie, ON Canada (~600 ft elevation), do you guys think this would be a good starting point for jetting?
Thanks in advance!
Thanks in advance!
http://www.partzilla.com/parts/detail/honda/HP-16100-KZ3-J21.html
The stock jetting that comes in this carb will also work in your 03', but again not my favorite. Those Suzuki NExx series needles work, work very well for off road use. For straight MX I would probably suggest another jetting combo.
There is an unobtainable D shaped gasket that he is able to get with his HRC connections too.....
I just went through a total ordeal, I wish I saw this five days ago.
http://www.vitalmx.com/forums/Tech-Help-Race-Shop,42/2003-CR250-No-Idle…
Yeah, give him a shout on that gasket
Looking forward to getting it installed, I'll report back with the results!
Remember the jetting that you have listed above is going to be lean for this time of year in Canada. You will need a few more jets and the richer needle if you are planning to ride the bike now.
Any ideas? It sounds like something must be off since Digger's jetting has so many great reviews.
Thanks again!
Broken reed...
New reeds!
Torque spacer before removal....not sold on them at all!!
Post a reply to: 2003 CR250 Keihin PWK Conversion
