Lisle, IL
2789th
So, I got this bike for a steal. Bike has very low hours, less then 30, all stock except for an FMF pipe and silencer. My problem is with the jetting and idol. I cant seem to get the jetting right. I went with what FMF has recommended for the pipe and year, and thats a 400 MJ and 40 PJ. I feel like it loads up and is running very rich. My air screw was 1.5 turns out as well.
Does anyone have any idea whats going on??
FYI - I tested with many pipes when these bikes 1st came out & the FMF Fatty was by far the worst performer IMHO. It was a mid-range pipe as it concentrated the power in that part of the powerband.
One of the main issues is the oem S-9 nozzle that came on the 02-03 CR2 mikuni's. Honda changed it to an S-7 (2 sizes leaner) on the 04-07 models shorter version tmx equipped with TPS.
I tried a JD kit as well & didn't like it so I went back to the oem needles. His kit back then came with an S-4 so it shows you how much leaner he went with the nozzle. He has since reconfigured his needles a few yrs. ago to work with the oem S-9 from my understanding.
I picked up another 07 cr250 last week and will be doing a bunch more testing with that carb and bike soon. I'll test it back to back against my 07' cr250 equipped with a 38mm PWK.
I owned an 03' cr250, but have since lost my notes for that bike with the TMX carb. I believe I used an s-7 needle jet, along with 1mm removed from the slide cut away. I think they came with #5 slides. A 32.5 pilot the stock needle and a 410 main.
The low end seems to be ok, but wont open up mid and top end.
Below are PC's recommended jetting specs. Just choose the yr. & it will show the 02-03 using a stock oem S-9 & the 05-07 using an S-7. https://www.procircuit.com/jettingspecs3.htm
The S-4 nozzle in the JD kit back then was recommended for the 01-03 TMX. Same needles were also used for the 04-07 short body equipped with TPS.
JetsRus still has nozzles available for the mikuni's to be able to fine tune the carbs.
Scroll towards the bottom of the pg. & it will be the 633 series nozzles for the 01-03 TMX Mikuni.
http://www.jetsrus.com/a_jets_by_carburetor_type/needlejet_jets_mikuni…
Post a reply to: 2003 CR 250
