Hi guys,
Busy throwing in a new piston for my 125 .
I read a few threads about checking for vertical play in the rod bearing although I cant find a straight answer for side to side play though . Some threads says its good and it should be like that and other threads says its bad .
Side to side play for me is about 1.5mm to each side when moving the rod side to side .
No vertical play whatsoever .
Will post a video later about the side-to-side play if that will help.
Should there be side-to-side play or not ?
Thanks and sorry if its a dumb question , I'm on a tight budget with my 125 build and dont want to waste money on parts that dont need replacing.
Instagram : @eondeysel974
