2002 cr125 waterpump wistle fixed but back to leaking
2/22/2018 5:38 AM
I rebuilt my waterpump recently with all new gaskets, seals, and a bearings and now my water pump whistles, but it not does leak coolant at all but it does wistle pretty loud. Any help is appreciated.
2/22/2018 8:18 AM
How’s the bike run? Whole different machine, but on cars, when the water pump whistles it’s usually because the seals are bad.
2/22/2018 9:02 AM
Id guess you put a seal in backwards or didnt put grease on them. Also how is air getting in to whistle in the first place?
2/22/2018 11:52 AM
Edited Date/Time: 2/22/2018 11:53 AM
Did you forget the washer that goes in-between the impeller and the shaft. (cr250 has this not 100% the 125 does)
2/23/2018 2:05 PM
Either sucking air or impeller rubbing housing.
2/23/2018 4:48 PM
Watching to many andy griffith reruns?
3/12/2018 6:16 AM
the wistle is now fixed and the only think left to replace is the shaft. can that alone cause a leak?
3/12/2018 6:35 AM
Yea if the shaft is damaged then it wont seal correctly.
