Edited Date/Time:
Ok so here’s the story. I was at an arena cross race and I shattered a clutch fiber on the way back from the truck after practice. The fiber was in like 8 pieces and some pieces were on top of one another. I pulled out the old clutch pack and threw in a good used clutch pack pressure plate and springs from a 2001 cr125. It rode fine for the rest of the night. Next morning at lakeside mx I ride for 20 minutes and after a rhythm section the bike box down much like a fouled plug and starts making a whining noise until it died. I kicked it when it was in gear out of curiosity and it barely crept forward. I put it on the stand and it doesn’t start. Fast forward to now I started it up and it make the whining noise. There is also a knocking kind of noise when I push the kicker down. I’ve pulled the water pump case and the basket off and everything looks fine. I don’t know if a piece of the fiber is still in there or where to look. Side note: the primary drive gear has some play back and forth between the basket and the basked has some mild notching. Any help is appreciated and I can provide pictures of parts if needed.
