2001 cr125 falling on its face
8/4/2018 6:47 AM
Edited Date/Time: 8/4/2018 7:04 AM
Bought this 01 cr125 about 2 weeks ago.
The bike runs, but it does not open up like it should.
Runs crappy through low, mid, and top.
Things i have checked:
-plug (new one installed)
-air filter (brand new, not too much oil
- fresh 32-1 premix
-Carb (rebuilt, seems too want leaner condition but doesnt help much)
-reeds and carb boot
-powervalve (was gunked up, but works freely now)
- compression (123psi, good quality gauge)
Im too the point where i think it could be a spark timming issue, or possibly bad crank seals. I do not have a leak down tester. But i am getting discouraged. First honda ive ever owned, think i should stick too yamaha. If anyone could offer some advice, i would appreciate it
8/4/2018 7:06 AM
Make sure the motor is good. Then clean and jet your carb.
8/4/2018 7:07 AM
Motor, as in the crank seals?
8/4/2018 7:21 AM
Everything. Your compression is a little low too.
8/4/2018 7:40 AM
Compression is very low. This will look like it is running rich as all the fuel will not be burnt.
8/4/2018 8:05 AM
Ok, and also i forgot too mention. When the bike is idling it will slightly rev up and down.
8/4/2018 10:19 AM
Edited Date/Time: 8/4/2018 10:20 AM
Air leak, but you need to address the low compression first.
8/4/2018 10:39 AM
Ok, i guess a rebuild would be a good idea, thanks for the info, i will get back when the motor is fresh
