2001 cr125 cylinder/piston
bh
Piedmont, SC US
Edited Date/Time 2/21/2018 1:04pm
the ring locator pin came out of the piston and caused this can someone tell me what caused this and if the clyinder can still be used.
Rohr144
Wentzville, MO US
2/21/2018 6:22am
Definitely not reusable. Gonna need to be replated. And not sure what would cause your issue.
Paw Paw 271
Benton, LA US
2/21/2018 7:34am Edited Date/Time 2/21/2018 7:35am
I would suggest you also look at the crank as it would seem that what ever caused this may reside there at this time. The cylinder can be fixed and replated.
bh
Piedmont, SC US
2/21/2018 7:58am
I would suggest you also look at the crank as it would seem that what ever caused this may reside there at this time. The cylinder...
The bottom notch was where the location pin was stuck to the cylinder and I pulled it off. 80% sure none of the piston got to the crank.
mx621
DE US
2/21/2018 8:07am
What brand piston? Check the exhaust bridge really close for cracks. I just went through this on my 02 cr125 ( same cyl ). The exhaust bridge can crack due to the power valve design. the pv design makes the bridge area very thin and pushes the water jacket away.
bh
Piedmont, SC US
2/21/2018 8:10am
bh
Piedmont, SC US
2/21/2018 10:27am
mx621 wrote:
What brand piston? Check the exhaust bridge really close for cracks. I just went through this on my 02 cr125 ( same cyl ). The exhaust...
The piston is oem, as about 6 hours on it
mx621
DE US
2/21/2018 10:50am
That’s not an oem piston. Ring stay is in wrong spot, wrist pin area looks totally diff, and that piston has markings on the top. This is a stock/oem piston
Piston in pic looks like it may be a wiseco. I’ve herd people having issues with the numara ebay pistons simulate to what you had.
Tracktor
The RTF/Amboy, WA US
2/21/2018 1:04pm
mx621 wrote:
That’s not an oem piston. Ring stay is in wrong spot, wrist pin area looks totally diff, and that piston has markings on the top. This...
Yep, Namura is shit and the wrist pin clips are basically made of solder. Seen them fail personally a few times and the ones that stayed in almost fell out when I went to remove them. Never. buy. Namura.
Now would be a good time for an HPP cylinder swap though........
Post a reply to: 2001 cr125 cylinder/piston
