Port Charlotte, FL
2007 rm 125 won't kick start ,check new plug wet ! But spray same fuel that I used in tank into air box close to carb throat 2 kicks start then stalls what is going on ? Can low compression cause poor fuel atomization of fuel ? Help
Because your plug is wet, it could be that you have flooded the crank cavity with fuel and until that is cleaned out it will not start.
Post a reply to: 2 stroke start ?
