Temple City, CA
11/16/2020 3:33pm
Does anybody have a idea why a two stroke would cut off in 4th gear at 50 mph and lock up the rear wheel... Then start up again like nothing happened and ride fine for another 10 to 15 miles then do the same thing... Its such a weird issue.
Plug is not fouled
Carb has correct jets and fuel is flowing good
Air filter is clean
Clutch basket and cable are solid.
This is not my bike, its my buddies. And were brainstorming on what the issue could be.
Plug is not fouled
Air filter is clean
Scooters are a strange breed. Does yours have a clutch, like some Vespas? Try turning off the run switch every now and then to get a blast of fuel/air mix through the cylinder when you ride. (Leave the throttle partially open.) When you turn it back on, the engine will bump start and you'll go back to normal, but with a cooler engine.
Post a reply to: 2 stroke issue (street)
