1999 KTM 380 SX Forks. Can I put newer inverted forks on it?
8/26/2018 9:18 PM
I have an amazing 1999 KTM 380 SX. I picked it up for 1000 dollars 10 hours after he put it up for sale. Mint bike. Rarely used and was owned by an old person. It sat for about 3 years and I got everything going but my forks are to old for my local fork builder to work with. Could I put 250 sx forks or 300 sx forks from 2009 on it? Thanks for all the help.
8/27/2018 2:41 AM
Aren't they the wp magnums?
8/27/2018 2:57 AM
Edited Date/Time: 8/27/2018 3:01 AM
The 1999 steering head bearings, top cover, top seal and lower cover / seal are the same part numbers right through to 18, and I suspect they are the same for 19s.
Steering stops - I don't think the 99s used the 2 bolts as a steer stop, but it would not be hard to make it take that set up - it's just an internally threaded piece of tubing welded on the frame. Can't get much more basic than that.
Not sure about the respective lengths of the frame steering head / triple clamp steer tube, but heck, I was able to fit a WP CC 48mm front end onto a Honda, whilst still using the Honda front wheel........There's not much that can't be done, if you put your mind to it.
8/27/2018 9:18 AM
Edited Date/Time: 8/27/2018 9:19 AM
WP Extreme fork...50mm. Marzocchi had the Magnum name. Should be an easy switch, shame parts are hard to come by for the Extreme fork, excellent unit, albeit heavy.
8/27/2018 1:17 PM
I bought a 99 380 , 3 years ago to put away in the garage , as I owned a new 98 380.
It has USD forks fitted on it looks like, complete with triple clamps is an easy swap. Photo
@TONY351KTM
8/27/2018 9:27 PM
Awesome. Thank you all for the help. Think I'm going with the 2008 250 sx forks.
