1999-2001 yz 250 left side crankcase
6/27/2018 8:52 AM
im looking for the left side crank case for 99-01 yz250 two stroke or a full bottom end setup must not have any cracks or jb weld of some sort as mine already has that.
6/27/2018 11:29 AM
Most Yamaha's will require that the cases be replaces as a set.
6/27/2018 12:16 PM
What year bike do you have? 99 to 00 take a different collar on the primary side.
I believe you can use your crank in any year cases, with swapping some seals, flywheel, and primary gear, depending on your year crank.
6/28/2018 9:10 AM
i have a 1999
