Edited Date/Time:
Trying to rebuild my set of 97 Honda forks.
I cannot get the slider removed from the outer.
I tried 10 or more times by pulling the slider quickly to bump the inner seal from its seat. It will just stick at the length of its travel. I need to hit the axel end with a rubber mallet to knock it away from where it sticks.
The seal shows no signs of moving.
Everything has been removed internally.
Additionally on my second image shows the polished part where it ends is not even in its circumference. I expected that part to simply end evenly around the slider. It is higher on one side. Is this normal? I assume above that is normal in its appearance also.
Looking for any and all help on getting that slider away from the outer....
Thanks in advance for any and all help...
