Johnson City, TN
85CR125
12/28/2019 2:39pm
12/28/2019 2:39pm
12/29/2019 7:07pm
Any suggestions on the best way to remove the hardened gunk in the water pump area? Any type of cleaner/chemicals, or just straight up elbow grease? This is from the all too common water pump rot on the older CRs.
You can try muriatic acid SPARINGLY as it will help dissolve aluminum when you scuff a cyl from a lite pistone seizure
I personally never tried it on Magnesium
Be careful.
Post a reply to: 1985 CR125 Water Pump Rot
