So I picked up a nice 19 350 sx with 9 hrs on it for 7k as a second bike. I already know the air forks suck so who makes a good spring conversion that doesn't cost as much as cone valves ( might go that route too if I can find some ) . Thanks in advance
Lainer, KYB, ohlins and MXTech all make great kits to convert both fork tubes.
Make sure if you do go with a conversion kit of some sort, have the valving set up to suit.
If you don't like it and want a spring fork, avoid the cheaper single sided spring kits. Go for a proper cartridge kit for both fork legs or a whole fork.
It seems the spring conversion kits are about $1800 and up. Too much money for my age and speed.
A friend had a full Öhlins fork and switched to the Reiger single side spring conversion and loved it.
That said, I rode with a guy last week who has his own suspension shop. He has made night shows in sx and still flies and his 350 just has a revalve. He’s had factory wp suspension on past bikes and he said everything that I like about my luckies feel wise could be accomplished with a revalve. He didn’t talk badly about spring kits but said if you just want the comfort and plushness out of the aer it can be done pretty simply with better valving fwiw.
Depending on where you are you have options for installers. JBI, MX Tech )of course!), and here in the PNW Dynamic Ride are all very familiar with the Lucky system.
Hammer 663s
I’m about to get my forks done while recovering from an ACL. I’m really leaning towards having MX-Tech do the Lucky Gen-2. However, for $300 less I can have the RaceTech spring conversion, re-valve, have the shock serviced and re-valved and have a bladder installed.
Do I get the Lucky’s and know I have some of the baddest forks available and do the shock later ORRRRR do I go RT and have the front and rear done?
Vet Intermediate 90% track 10% woods.
I’ve come to learn that it’s less headache if I just spend the money once vice trying to save a few bucks later on. What’s the point in having the best forks if the shock isn’t up to par?
Post a reply to: 19 ktm 350 spring conversion ?
