Ruskin, FL
Have a 19 KTM 350 that since day one does not want to shift from 2nd to 3rd under power even when dabbing the clutch. Basically have to let of the throttle to get it to shift. Bike has 2.5 hours on it and it’s been like that since I bought it new.
Anyone else having issues like this?
I actually did hit one false neutral was coming out of a corner and was trying to get it up a gear and I was fumbling with the clutch and right before the jump I hit neutral. The other half of the time I was hitting jumps A gear too low because I couldn’t get the bike to shift.
I am also running a 52, UnFortunately some of the jumps you need 3rd that are about 50’ out of the corner.
I’m going to try to adjust my technique a little, been riding 35 years and never had to before but this bike might just be different.
Do you have an issue with the bike stalling in corners at all? Last weekend I stalled it like 5 or 6 times jumping into a corner, clutch in and just cut out. I’ve also noticed a few times if it’s on the stand and I rev it that it will just cut out after the RPMs com back down. I brought this up to the dealer and he said KTMs are notorious for that and that I need to run my idle extra high. Never had these issues on my 250sxf
I am running Motorex 10 W 50 also and have already changed it once after The first ride.
Post a reply to: 19 KTM 350 shifting issues, anyone else
