2/15/2019 5:21 PM
Edited Date/Time: 2/15/2019 5:23 PM
Fair enough.
Mapping the ECU to alter the air/fuel ratio at different intervals throughout the RPM range seems to be where the MX engine tech’s are spending a lot of their time. Through dyno runs and lots real of real world testing, tech’s are altering the air/fuel ratio to complement a comprehensive view of all engine specs. Everything from fuel, engine & associated componentry, ambient temperature, altitude and more is accounted for. Generally on a 450, they will develop the map to broaden and smooth the curve. Re-Mapping services from Twisted Development, Tokyo Mods, or any other reputable company will run you about $100. There are some on the east coast too, they may have a better idea about local tracks and conditions. You’re right about the bikes coming too lean from the factory to pass emission testing. A proper ECU tune will correct that and is definitely one of the low-hanging fruits.
On a bit of a tangent but...
I have only heard of one other person here comment about the lack of power from a 450. IIRC, he also had a street bike background. I think once you throw in challenging track conditions and long motos, you’ll find a 450 to be quite a handful. I honestly don’t believe a MX racer would benefit from a more powerful engine than the current 450s. Manufacturers have no reason to make a 70hp off-road race bike because the market doesnt demand it. Whereas the road racers can actually benefit from 190hp vs say 160hp? IDK to be honest.
I can understand you would find the power is underwhelming compared to a street bike, especially in a field or groomed track. But under race conditions, you may find you can put in a better moto on a tamer,stock engine than an aggressively hitting, stamina draining power plant.
Or maybe not. In that case, another low hanging fruit is to remove the back fire screen in the filter cage. The two stroke SX’s have no screen in the cage and can be fitted to the SXF’s. Be sure to Mention that mod to the person that is doing the remap too.
I’m curious, with your street bikeground, what separates the two engines that the street motor is capable of 190hp/liter vs the dirt motor? Which by my calculation is more like 130hp/liter. Doesn’t the fact it gets to share the load with 4 cylinders help push the envelope of max HP? As far as I knew, a MX-450 (especially KTM) is the most powerful single cylinder I.C.E. made per CC.
