hbdesigns913 wrote:
I may try that out. Thanks. Just seems something is not right with mine. All the bike test and no one has mentioned how touchy ...more
hbdesigns913 wrote:
I may try that out. Thanks. Just seems something is not right with mine. All the bike test and no one has mentioned how touchy the brake is.
Have you tried bleeding the system and putting in dot4 brake fluid? Remove the calliper and pump the brakes to bottom out the two pads on each other then see how much force it takes to push the piston side pad back home all the way, could be a seized piston in the calliper. swap out brake pads and while the pads are out and front wheel still on the bike grab a green or maroon scotch bright pad, spin the wheel and scuff up the disc surface while going from inside to outside in a waving motion both sides of the disc. Remove the front brake lever from the master cylinder clean everything and reassemble it with some good grease on the pivot bolt and make sure its not too tight.
Instagram @_yabba_dabba_dont_
