- Pick trends
- Create a private league
- And more!
How noticeable of a difference was it for you? I haven't spent that much time messing with the machine, and have been sitting back reading. If someone has a worthy setting, I'm all for trying it out.
I do have pipe, silencer and vforce reeds if that comes into play... Thanks again for the insight.
Running 50:1 premix using BelRay H1R
MJ 470
PJ 32.5
Slide 5.75
Needle 42-75
Clip 4th position
Needle jet s-4
AS 2.0
C12 mixed 60:1 with amsoil donionator
Elevation 560'
Depending on the temp you'll have to adjust the clip. It was warmer this past weekend and I had to drop back to the 3rd clip position as it was in the low 70's. You might want to try that set up, but use a 460 main jet and 1.5 turns on the air screw and see how it runs with pump gas.
If anyone has feedback on the 5.5 slide I'd be curious to hear.
PC pipe and silencer
110 sunoco 60:1 with synthetic maxima
v force reed cage
440
42.5
2nd clip
I did not read through this whole thread so sorry if porting has been discussed.
Last thing I want to do after dropping 8 grand is mess with jetting and carb bs. I’m coming off a FI 4 stroke.
MJ 470
PJ 32.5
Slide 5.75
Needle 42-75
Clip 3rd position
Needle jet s-4
AS 0.5
Generally the bike felt really good and I had very little inclination to mess with it other than to validate the settings. If anyone is going to try this setup in a similar environment I'd try a 480 main. Top end felt a little bit chained. I'd have tried it myself but I ended up running out of time. Happy day!
http://www.jalos.or.jp/onfile/pdf/2T_EV_LIST.pdf
Do you like the red spring better than the stock? I'm running the stock spring 1 3/4 turns in and the bike is amazing.
As for the jetting I'm happy with the current setup and got nothing to complain:
- PC 304 silencer
- Squish tightened from stock 1,5mm to 1,2mm
- Jetting stock except 37.5 pilot and 460 main
- Red power valve spring 1 1/4 turns in
Post a reply to: 17' TC250 Jetting Help
