rollin64caddy wrote:
I'm hoping saturday. I had an issue with the schrader valve in the forks leaking last weekend so i have to get that fixed ...more
I'm hoping saturday. I had an issue with the schrader valve in the forks leaking last weekend so i have to get that fixed also.
opyguy wrote:
what happened? I ride 1.5 hours yesterday to get to the track, got there, set my air pressure and forks wouldn't hold ...more
opyguy wrote:
what happened? I ride 1.5 hours yesterday to get to the track, got there, set my air pressure and forks wouldn't hold pressure, definitely leaking (fast) @ the schrader valve. I got lucky, someone had one and I just replaced it, was able to ride, but it worries me. lml what you end up doing for fix
Had this same problem on my 16.5 450 FE air forks...I just used an old valve from an inner tube! Happened at Southwick one day....I was pumping them forks like a madman to get the pressure back! Bought cone valves the next day ...have had the cone valves on my 18 250 Sx since new, just for comparison I ran the stock airs last week at my local practice track as I sent my conevalves out for service......instant arm pump........I think my 18 has the same jetting as the 17"s, I"m 1 step leaner on the pilot, stock needle on 3 rd clip, 2 steps richer on the main, 450 In warmer temps I will try 2nd leaner pilot. Fmf fatty & standard silencer, 50/50 race gas & non ethanol @ 50:1...I set my gearing & powervalve same as MXA suggest, bike rips, but a lot more work than a 450!
