- Pick trends
- Create a private league
- And more!
Needle: 42-74 in the 3rd clip position
Pilot: 32.5 pilot, with an unnotched slide, and a 30 with a notched slide. I wouldn't be afraid to open up that notch on the slide you pictured above a little more.
Main: 490
S-4 jet needle jet---this is critical
Slide: #5 you can either cut yours or purchase one from JD jetting.
Set the air screw at 1.5 turns out to startout with.
If you're not going to cut the slide into a #5, or replace with a #5 slide, none of what I posted above will work. It needs to be done in tandem with one another. It's not a piece meal setup to be done one at a time.
How far away from Edelman's KTM are you ? I believe they have all of what you need in stock, with the exception of the slide.
https://jdjetting.com/product/jdmk05-mikuni-tmx-jet-block-kit/
https://jdjetting.com/product/jdmk02-mikuni-tmx-ktm-husq-carburetor-sli…
How’s this look? I used a 7/32 file still waiting on S4 and new 42-74
Here’s a stock #4 slide that recently cut into a #5.5.
Is this the part you cut down? I only ran a file through the notch on my slide that’s it
Your slide will only need to be cut 1mm for 125's and 150's.
So this just happened lol.
my 16 150sx had this problem & it is somewhat common
Post a reply to: 17 TC 125 cutting out
