Kennewick, WA
motokawi818
1/9/2018 1:29pm
1/9/2018 1:29pm
1/9/2018 3:52pm
I'm going to swap the springs myself, so I'm wondering where I should purchase the springs from. I have decent local pro speed, at 175 lbs, and these spring are way too soft for me. Constantly bottoming out. I have a friend willing to swap his stiffer 18 rear shock spring with me, so I was also wondering if I should just purchase stock 18 fork springs from motorsport or go to an aftermarket dealer. Also, if I'm bottoming these out so bad, should I go up two spring rates or would just the one jump be good enough?
Thanks!
Edit* Is there a difference in spring quality from and aftermarket dealer and stock springs?
Thanks!
Buy the strongest spring made for your bike, install them but leave the oil out and you not only will bottom out on the landings, but the takeoff as well. Really light springs and thick oil, as long as the shock/fork fully extends while airborne, you'll never bottom out even flatlanding. This is just an example but shows the function of the components.
I'm not saying you don't need springs. Spring rate and length are a specific part of suspension and how it handles. Don't know if there are different lengths or not for MX bikes.
The right spring rates keep the suspension where you want it during braking and accel. Fork springs too light and you could bottom out under hard braking or simply be way too close to the bottom of the travel. Dampening has no affect here.
Get springs for your weight, change dampening to keep from bottoming but too stiff dampening and you lose cornering grip.
Sorry didn't mean to take it out that far... but you get my point.
1. Spring the bike for your weight
2. Adjust clickers. If compression is maxed and your bottoming, go to step 3.
3. Add oil or use thicker oil.
4. Revalve
5. Even stiffer springs
6. Step 2-5.
Landing a jump ( springs 1%, dampening 99% )
Braking into turns with braking bumps ( springs 30%, dampening 70% )
Post a reply to: 17 crf450 fork springs
