North East, MD
5/1/2018 7:18pm
I was wondering if anyone has experienced the problem I am having with mine. They hold themselves up in the stroke well in low speed conditions such as braking hard on corner entry but they blow through the stroke and bottom hard on small high speed impacts when they shouldn't be - my wrists are throbbing after riding the bike. I have gone stiffer on the compression clicker and added up to 18psi to the outer chamber which seemed to help but the fork became harsh and I experienced a loss in traction. What I have found so far is that adding 10 lbs. to the inner chamber has allowed me to run a softer compression setting without sacrificing performance. This has helped but it still isn't where I want it. I'm not sure that adding pressure to the inner chamber is the right route since it is essentially my "spring rate" but it is definitely helping. The forks have been re-valved for 195 lbs B rider and they have me at 145 inner 9 outer 205 bal. Currently I'm running 155 inner 18 outer and 205 bal. All I want to know is if anyone else has experienced this and has any input.
also im fascinated by the pressure you have in the inner of 145.. (we probably use different people but i run mine at 185-7-190 but i may go up in the balance chamber the next time i ride and see how that feels. )
155 IC for 195lb rider seems low and 205 BC is super high. Isn't this set up making your forks run a lot of sag? Your front end is likely dropped in the stroke.
For comparison I'm running 185 IC to 168 BC with 0 outer chamber in my RMZ450, I'm 190lb B rider as well.
I have never liked the way the forks work with a balance chamber pressure that is higher than the inner chamber pressure, but then as previously mentioned it really depends how it has been valved.
Trial and error is the key to setting these up, it takes time but try everything and document it. You will find a good setting soon enough
@RussB- its a KXF
They take the big hits way better with the revalve....
I'm probably going to do a spring conversion at some point just because it's kind of pain to maintain air pressure over a day. Performance of the fork is way better than stock, I highly recommend having them for a revalve.
Love these Showa sff forks. Thanks TBT!
I have 2011 forks on my 2016 with FC valving and .50 springs with a MXTech revalved shock with low friction piston band and 5.7 spring. I’m a 190 pound Vet B rider.
The second photo i have the ohlins conversion on the air fork.
Post a reply to: 16 Showa SFF TAC Fork
