Edited Date/Time:
There is no way this linkage bolt can be this hard to remove. I’m talking about the bolt that mounts the pull rod to the frame. I’ve removed the nut no problem, which is what gives everyone problems, but the 17mm bolt will not slide out. Ive aplied penitrating oil, used a 2x4 and hammer and also tried using a tire iron while ratcheting the bolt out. Ive heard they are a pain to take out but what’s the trick? Is it also threaded into the frame or just the nut?
