GREENFIELD, MN
3595th
10/30/2021 4:50pm
Bike starts normal and within about 15 seconds of starting it will die. I can start it again but the same thing continues to happen over and over again. Bike has been sitting for multiple years.
Please help me get pointed in the right direction!
Also, I should have clarified that to me it did not sound like a fuel starvation issue in that it was a very fast shut off. Like it starts, runs for 10-15 seconds and instantly dies. This bike has less than 20 hours on it from new.
Go with new injector or hope you can clear yours out
run down the electrical-voltage reg, condenser
Connect injector to bike out of the body and see if sprays fuel
What Factor E is suggesting to do is... pull each injector out of the throttle body & intake boot while the injector is still connected to the bike’s wiring harness & fuel line. Then attempt to start the bike and inspect the fuel injectors for a healthy spray of fuel. It should mist fuel.
Check TPS output voltage as well if after you see the injectors working properly under the bike’s own power supply.
test light or meter to connector test for power
If nothing its a harness problem
Trace wires back from injector for damage or pinched wires
Test capcitor
Post a reply to: 13 Kawasaki 250F issue
