Mansfield, OH
About a year ago i rebuilt my kx250f. New everything in the engine. Couldnt figure out the problem then and im just now getting back to it.
Valve clearance: I=.15 E=.20
Leakdown= pass
Compression=~82PSI
Timing correct - 28 pins dot to dot and 12 between middle dot with TDC marks aligned
No airfilter installed at the moment
Dripped gas directly into the cylinder to bypass any carb issues
Stator resistance is within spec and no shorts to ground
Bright blue spark
The only thing this bike will do is afterfire from time to time. Im leaning towards a CDI issue. Thoughts?
Leakdown= pass
Compression=~82PSI
Bright blue spark
Carb condition?
Are you sure you are using the correct valve clearance spec's?
08 rmz450 found a slightly bent valve. Spark and a back fire while kicking.
12 rmz450 weak flywheel magnets. Spark tried to start but wouldn’t.
09 crf450r. Had spark no start. Replaced wiring harness and ecu at the same time and started right up.
16 kx450f spark no start. Replaced flywheel and stator at the same time and it started right up. Stator ohms were within spec but I replaced it anyway for a piece of mind.
So to make things confusing, the service manual says to time the cams with the TDC mark, however if i rotate my flywheel to the timing mark, the cam markings are about 1 tooth off clockwise.
I ordered a new CDI. I dont know what else it could be besides some electrical part that got messed up sitting on the shelf over the winter
Question, is there anything in the carb that can cause symptoms of a air leak? Im going to order a new intake boot and want to order any seals i might need to fix it
Post a reply to: 09 kx250f no start (revisiting)
