I am still trying to resolve my hot starting issue. When warm, it takes about 6 good kicks for it to start and will only do so with wide open throttle. Lately, if it doesn't start, it floods. I just raised the float height and will try that.
I went through the electrical and now have this question:
How far out of spec can the ignition coil be before it causes symptoms?
My secondary winding shows 17k ohms, well within spec.
My primary winding shows 2.5 ohms and spec is between 0.17 and 0.70 ohms.
Is the coil junk and causing hard starting when warm.
Thank you
