04 Cr250r internals into 05 cases?
11/13/2018 6:59 PM
Hi all, wondering if anyone knows if possible to use 2004 Cr250r transmission clutch etc into 2005-7 cases? I don't think 04 cases are still sold by Honda. I will be bolting on the 04 cylinder as well. Is this possible? Anyone else tried it?
Thanks in advance
12/20/2018 3:27 PM
Bump. Anyone tried this ?
12/21/2018 5:46 PM
I am
Pretty sure that 2002 through 2007 CR250 engine all have the same cases. The only differents is they changed cylinders in 2005.
12/21/2018 11:35 PM
Edited Date/Time: 12/21/2018 11:45 PM
matt.3150 wrote:
I am
02-03 have the same cases with the 03 having thicker stronger gears.
04 cases are different & a 1 yr only design.
05-07 cases & internals are the same.
02, 03 & 04 cyl's all have different oem porting specs each yr. with the 04 having a different spec head.
05-07 cyl & heads are the same.
12/23/2018 11:05 AM
Not saying your wrong but to me what your saying about the transmission sounds like the CR125 not the CR250.
12/23/2018 6:26 PM
Edited Date/Time: 12/23/2018 6:32 PM
Matt - I've owned (9) 3rd gen AF 02-07 models. That gave me an opportunity to gain some knowledge with that gen CR2's.
The 02-07 CR125's had similiar changes to the engines as well during the yrs. I posted above.
