North Charleston, SC
6/7/2020 1:14am
So coming off a fresh rebuild bike would start right up, time came to take it on it first ride things were fine until i tried to shift to second and like the bike just started jerking. So trying to find neutral and i can’t seems as if the clutch wasn’t engaging.Took it apart and found shift drum was bent replaced that but now i can’t get the cases back together, the transmission is catching on something i think or idek what’s causing them not to close evenly! I have some pictures to see if i put them in correctly, also the worse oil drain plug i’ve seen any suggestions to get it off?
Additionally check your bearings for straightness and your dowels are not banged up
That is a new one on me.
You can pull the crank in and gently tap it on the opposite side with a dead blow hammer. A lot of people will say not to tap the crank as you can unbalance it but a few gentle taps with a dead blow as you’re pulling it in will do no harm.
If it works you may hear a pop as it seats back in correctly.
Once you’ve got it in, check either side of the crank with a feeler gauge to make sure it’s completely central.
Edit -
Could be the pics but your trans doesn’t look to be sat correctly, I’ve added a couple of images below of my 2004 YZ250 trans before I pulled it out so you can see how it should be seated.
Use your case splitter to push the crank out and do a few dry fit test runs with your cases and transmission until you have it right.
I'm in the never hit a crank with a hammer camp... but that's just my opinion. Others may vary.
Your forks and drum appear correct, just your counter shaft not fully seated into its bearing and riding higher.
Post a reply to: 03 Yz250 Problems after rebuild
