02 cr125 waterpump
2/2/2018 6:38 AM
Im leaking coolant from the somewhere on the bottom of my waterpump case and im trying to figure out if its a gasket issue or if it is coming from the hole on the bottom of the water pump. if someone could tell me if it can and why it could come out of that hole on the bottom of the waterpump it would be appreciated.
2/2/2018 8:04 AM
You need to rebuild it.
2/2/2018 8:39 AM
Water pump seals are worn out. I would suggest replacing them as well as the bearing and also the shaft if worn.
2/2/2018 9:24 AM
What he said. Same thing happened to me on my 07. Replaced the seals and get a new WP gasket. All good now
