02-07 CR250R plastic changes
3/17/2018 12:26 PM
Edited Date/Time: 3/17/2018 12:27 PM
Good afternoon,
Had a question about changes in plastic between the 02 and the later CR250’s. I have an 02 and would like to update the front number plate and fender. I don’t like the new (ie 09-12 or 13-16) swaps at all. I’d like to just update to the later CR250 design which (I think) either started in 04 or 05. My question is this. If I order a plastic kit or graphics/backgrounds for, say, an 05 will it all fit my 02 (once I do the swap) or were there other changes? As far as I recall the only difference from 02-07 were the front plate and fender. I am aware of the top bolt on the front plate vs the front of my 02, that’s not an issue.
3/17/2018 1:13 PM
Yes it's all the same apart from the number board and front mudguard. Cycra sell a stadium plate which will fit. Fitting later model plastic is shonky as the later guard has a step, so you need to use spacers, and it looks like a lash up. Although Polisport have a restyle kit coming.
3/17/2018 2:35 PM
Thanks for the reply-and agreed on the newer CRF fenders...they look good on the bike they’re intended for, but in my opinion on a 3rd-gen CR they look like a mustache on the Mona Lisa...
3/17/2018 5:03 PM
You're spot on; All the plastics will bolt right up, minus the front number plate (due to the aforementioned location differences). eBay or an amigos 04'-07' CR125/250, 04'-07' CRF250, 05'-07 CRF450 top clamp (24mm) would give you the new top (not front) mounting.
