Colorado Springs, CO
11/17/2015 12:56pm
I just bought a 2015 KTM 300xc and have torn the valve stems off both the front and back tubes twice in 4 rides. I have never had these troubles before and I am installing the tubes the same as I always have. Does anybody have any ideas what could be causing this? I am running AT81 Dunlops and the rim lock is stock.
You need surprisingly little force on the rimlock to lock the tire in place. Also make sure your tire pressure is sufficient to keep the sidewall supported.
Basically, the tire is going to spin on the rim regardless of a rim lock. It might not be much, but it happens over time. The valve stem has to be able to tilt a little to compensate for that without tearing, and it cant do that with the nut on there.
Post a reply to: Valve Stems Keep Failing
