Rust removal works 2 stroke pipe.
9/16/2013 4:30 PM
As the thread title suggests I am trying to get thick rust off of a PC works pipe. I have been using steel wool, scotch brite and simple green. Any other suggestions?????
Go Hawks!
9/16/2013 4:42 PM
WD40 & maroon scotchbrite pads
“If I remember how this worked, you’d put a side on, and then you’d go and have something to eat, and then you’d put another side on.” … Mick Jagger
9/16/2013 5:02 PM
Castrol all wheel mag cleaner and scotch brite pad
9/16/2013 7:15 PM
Naval Jelly, make sure and wear gloves.
9/16/2013 11:44 PM
A bit of regular old tin foil and WD40 works as good as any other products I have tried.
9/17/2013 6:51 AM
TSP Tri sodium phosphate, sold at Home Depot. It should attack the majority of the rust before you go at it with a scotch brite pad.
9/17/2013 9:16 AM
I'm intrigued by the tinfoil comment. Does the aluminum react with the oxydized steel, or does it just mask the rust? Interesting...
9/17/2013 12:29 PM
I start with 400 grit and move up to 1000. then hit it with a polishing wheel on an offset grinder. If it's not shiny enough to see yourself, you're doing it wrong.
Juniormediate Pro
9/17/2013 7:19 PM
Phosphoric acid metal cleaner. Got a local automotive paint supplier? PPG sells DX579. Great stuff. Eagle One aluminum wheel cleaner from the auto parts store will also work. Scrub it with a scotchbrite. Keep it out of the sun and it will stay wet longer. Scrub it clean and rinse with water. Repeat as necessary until clean and rust free. Spray down with oil or WD40.
[LINK TO IMAGE]
9/18/2013 8:38 AM
The Works .... toilet bowl cleaner. DO NOT DO THIS ON THE BIKE!
http://www.theworkscleans.com/toiletcleaner.html
9/18/2013 9:13 AM
...unless your bike really IS a toilet...tongue pinch
9/18/2013 12:58 PM
it will cause every bare metal surface to rust .... nuts bolts ect.
9/19/2013 3:57 PM
Edited Date/Time: 9/19/2013 3:58 PM
Move to Arizona and never have this problem again.
My 125:
Powerband in every gear !
9/19/2013 10:41 PM
Definitely Ditto, and after it is clean, use the green scotchbright ,it's finer ,and will look even better.
9/20/2013 6:34 AM
My 125:
I'm calling shenanigans that looks brand new!!!
9/20/2013 6:37 AM
I used to used any penetrating oil and some maroon scotch bright...worked fine. If i wanted a smoother look I switch to a lighter scotch bright pad or a 2000 grit sand paper. When your done coat it again with WD40 or something similar.
Are you guys getting that much better results with all that special stuff you use??
9/20/2013 9:49 AM
It still looks like that after 2 years. I stripped the paint off the stock pipe over 4 years ago and it still has no rust whatsoever. I haven't touched it with WD-40, scothbrite, or anything. One benefit of living in the desert anyway.
9/23/2013 2:33 PM
jsmx97 wrote:
I used to used any penetrating oil and some maroon scotch bright...worked fine. If i wanted a smoother look I switch to a ...more
Special stuff? That depends on how bad the rust is. And here in Southeast Texas, it gets pretty bad. You can scrub all you want with a scotchbrite and WD but there will still be rust in the pores of the metal. The PPG Metalprep I posted up makes quick work of some really nasty stuff on a bare pipe. Just make sure the pipe is off of the bike as it will discolor cast aluminum and zinc hardware. Anything else I've found seems to take more time. If it's just light surface discoloration, other products and processes probably work just fine.
9/23/2013 4:08 PM
Edited Date/Time: 9/23/2013 4:10 PM
Go to the local swimming pool supply and buy a gallon of Muriatic acid. Mix about 4oz acid into 12oz of water in a plastic container. Always add acid to water, and not the other way around. Adding water to a strong acid can leave you without a face. Wear gloves and eye protection. Don't breathe the fumes.
Brush the solution onto the pipe and it will burn the rust off. Rinse with water and repeat as necessary. Finish with WD40 and Red Scotchbrite.
9/25/2013 11:29 AM
CamP wrote:
Go to the local swimming pool supply and buy a gallon of Muriatic acid. Mix about 4oz acid into 12oz of water in a plastic ...more
What he said, and if you get bored and want the get that cool look the pipe has when new in the welds, you can heat all the welds with a torch, the heat will make the metal become blue.
9/25/2013 5:09 PM
CLR, calcium, lime & rust remover, You can get it at Wal Mart Photo
Cleans it up like new, I've even used it on a works pipe where the rust was rough feeling, not just surface rust and it cleaned it right up
7/30/2019 2:50 PM
Winner 👍 Photo
7/30/2019 4:29 PM
Cleans it up like new, I've even used it on a works pipe ...more
Always had luck with CLR and a scotch brite pad
7/30/2019 6:23 PM
I used the tinfoil trick on a chrome axle ,it took off the surface rust but dulled the chrome out..
7/31/2019 9:11 AM
Tell me where to find tinfoil please.
I used Lime Away, same thing as CLR. Both go back to the 80's. There are a few better though more expensive metal preservatives but they all burn off in just a couple minutes. I use Fluid Film. You can get it at Home Depot.
7/31/2019 10:20 AM
Grocery store..
7/31/2019 1:18 PM
Edited Date/Time: 7/31/2019 1:19 PM
Ive used Coca-Cola and a scotchbrite on light rust, it may work on deep rust.
8/1/2019 9:41 AM
Seriously a gallon or two of white vinegar and some water, submerge the pipe in it over night or longer depending how bad the rust is.
$2 worth of product. It will come out nearly like new. Might have to wipe off some rust. Hit it with wd40 immedialy upon removal from the vinegar or it will flash rust since its bare metal again.
8/2/2019 4:42 PM
I have a pool, so I had some muratic acid, I mixed with water in a spray bottle... here is before & after with a scotch brite pad, about 20 minutes worth of sanding, then rinse with water, then wd40 wipe down. Photo
8/6/2019 6:38 PM
If you have access to a bench grinder, get a wire wheel on that baby and go to town. I did that to a bare pipe once and it came out like new.
Braaapin' aint easy.
