12/9/2015 5:42am
So what's the best way to get the snap ring out that keeps the shaft and valve stack inside? I have tried using a handful of screw drivers and a pick. The smaller ones generally bend and the bigger ones can't seem to get behind the ring (ground the blades of the screw drivers to a tip, as well as made the pick sharp). Obviously the shock shaft being in the way doesn't help.
I was thinking of using a dremel/drill to drill a hole above the ring and angle it behind it, so I can get something behind it (similar to how pistons are).
Any ideas? Persevere with screw drivers? It's even more frustrating because putting in a ring with holes probably would be possible!
Seal Remover, Spoon Tip, 5 11/32", Red
0 stars
11.45 USD
Item: SGSR3AR
Any idea on the volume of oil typically required for a shock rebuild? I have about 400ml left over from fork rebuilds (Honda Fork Cushion Oil 5W) but I think it might be a little short.
Also, fork oil is not suitable for use in the shock.
Thanks for the tips though. And the hole is covered by the ring but I have made sure everything is flush. Now waiting for the parts to arrive.
Post a reply to: Rear Shock Snap Ring
