Delanson, NY
joemoto883
3/20/2016 7:50am
3/20/2016 7:50am
4/3/2016 4:18pm
Just picked up a 2009 RMZ 450 from craiglist as a project. Bike is not getting fuel to the motor, so far i have bench tested the fuel injector and fuel pump (both work as they should) I have tested the plugs that hook to both for power also and as far as I can tell I'm not getting anything to the injector. Bike has good spark and compression, engine is in time (according to the timing marks on the stock cams). so what's left??? ECM? Tip over sensor? Crank sensor? really want avoid throwing money at it and going in circles. anyone have an experience with this? HELP!!!
If you put 12v DC to the injector, you may have ruined it, they work of sub-5v. Test the injector resistance itself, RMZ450 injector resistance is around 10 ohms (9.5-11.5) @ 68 F. Also test front each prong to ground (should be inifinty ohms)
https://jet.com/product/detail/456897eb438448a7986feb208b02b1a3?jcmp=pl…
Post a reply to: RMZ 450 no power to the fuel injuctor
