Wallingford, CT
7/31/2013 9:13pm
Bike has about 80-90 hrs since I did a crank, bearings, seals (more of a precaution before last season). Went riding last week and after a couple moto's started hearing a ticking noise like an exhaust leak on a car. Pulled right over and looked all over bike. No exhaust obvious exuast leaks, header nuts seem a little loose. Tightened started it and it was fine. Did two more moto's went home and washed bike. Was changing the oil the next day and I pull the filter and see some metal in the filter. Pull ignition cover and see metal dust on magnets and the spring for the crank seal laying there and it has crank gear teeth marks in it. Crank seal seems to be chewed up and loose. Pull engine, head and cylinder look good. Piston skirt has some scouring which was weird since the cylinder was perfect. This is a JE 13.5:1 that was just done about 10-15 hours ago. Any idea as to what could cause this? Just a fluke thing and the spring let go. Bike was running perfect and showed no signs of a problem other than the ticking noise that had gone away. Thanks for any help.
I guess if it were in correctly the seal could have popped out and the spring eventually ended up breaking and falling down in the timing chain.
The seal could have just not been seated properly, pushed in too far, not far enough. Nothing in the bottom of the crank area should have caused it to blow out.
Double check all the cam journals. I'd guess that seal is there to direct the oil into the sump for pumping back onto the head. Without it, it could have starved the valve train for oil.
The left seal had the spring facing in towards the crank. Bike ran fine, no smoking, lose of power or anything.
crank bearing didn't move when i looked closer
only other stretch i can think of is the mains spiining in the case and it caught the seal and spun it out...getting a new case solves this problem but im curious to know if the bearings did spin or not..again a lot of ifs
these are just floating ideas since your the only one that can see the motor lol
I'll check all lines. I did know it was smoking out the breather when it was making the noise and may have been after. It was blue smoke. I didn't pay to much attention to it since it was nearly 100 degree's out and very humid.
Ended up getting a new cylinder and head. Not worth playing games at this point. Might have to stop using Honda GN4 oil and go synthetic too.
Post a reply to: Need Help ASAP! 09 CRF450R ate crank seal
