Cumberland, MD
1/25/2012 5:11pm
So i just bought a 2008 kx250f. My first 4s. It has stage 1 hot cams, a PC high comp piston and some jets. The guy i bought it off of never told me what jets where in it. Well im trying to get it running, it starts perfect and has great compression. the problem is when i rev it, it boggs down at about 1/4 throttle. Any Ideas?
My dad said screw the air/fuel screw in all the way then back it out 2 whole turns, add some new gas and it should be fine...
ANY IDEAS?
ANY IDEAS?
If so, drain your gas. Get a can of carb cleaner and clean the carb and jets. Put some new gas in the bike and see if that fixes the problem.
If the bike has been sitting for a period of time the carb may just need a good cleaning.
And why are you posting this in the Moto Section instead of the RACE SHOP section of the forum?
darn noobs.
How about you take the jets out and READ what they say on the bottom. Then - go to the manual and READ what it says for temp, heat and elevation.
Sorry Greg - there is no magic dust for motorcycles.
Im going to try Some new gas and see what happens...hopfully i can figure this thing out.
More than likely you are going to have to do 2 things;
1. Clean the carb and get some new gas
2. Make some jetting adjustments.
If you have the owners manual it should tell you what jets are recommended for what temp ranges.
You can start there as a base. or just clean the carb and wait until spring when the temps warm back up.
2 strokes with direct or fuel injection. Now that will be very good. 2 strokes will not have to worry about something like that, and they will last much much longer for everyone.
im gonna do the gas and cleaning first and wait til it warms up a little bit haha!
damn ethanol in the gas is bad for carbs
If you are looking for advise here on a motoboard, you don't need to own a modified 250F.
chill out hoss
I'm waiting on warm weather too but my bike is a fuely.
For final clean up / rinsing of the carb, I use brake cleaner or contact cleaner. It dries clean with no residue.
Post a reply to: Man 4-strokes are pains... HELP
