Big Sand Whoops, MI
334th
11/29/2017 2:56pm
Ok fellas,
Is the 38mm carb worthh it on a 250 sx or is it only needed on the 300 sx?
I'm looking at them online and was curious if I could just get the pwk air striker carb with the screw top, or if I had to find one with the top plate like the stock 36mm?
Looking at this one.....
It'll help on the stock top end right? I don't need the 300 kit to notice a gain?
Also means I have a brand new 36 carb if anyone needs one...
Shane
2013 125SX - 50331101544 - CARBUR. KEIHIN PWK 38S AG
2013 150SX - 51531001444 - CARB. KEIH. PWK 38S AG BC0
For instance, Honda uses different letter combinations in their part #'s to designate models like KRN or MEN. Even though the 2007 CRF 450, 250 and CR 250 use the exact same fork seals and bushings, they will have different #'s depending on what microfiche you look at.
Big brother will have all our moves mapped out for us before we even make a decision.
Shane
http://www.motosport.com/dirtbike/oem-parts/KTM/2014/125SX/CARBURETOR?f…
What I received is pictured below. Note that this is not a screw top like MxKing809 showed in his first post:
Now, I've realized that Digger29 specifically recommended the 2013 125sx carb.
However, there seems to be no difference between the 2014 that I ordered (in the link above) and the 2013 in the link below:
http://www.motosport.com/dirtbike/oem-parts/KTM/2013/125SX/CARBURETOR?f…
--Do all 2013/14 125sx's come with screw tops?
--Was the screw top phased out in 2014?
--Have I received the wrong part?
What are the benefits of running the 38mm rather then the stock 36mm?
I was under the (wrong) impression that the screw-top was the stock carb on 13/15 125/150sx --it is not.
I'll post again after testing it tomorrow.
I have similar jetting to above (with my stock carb) and I feel like my bike runs sweet.
I'll see about the VForce next. Did you try it with the stock Posion Rad valve?
Post a reply to: KTM 250 SX Carb Swap
