Julian, NC
6/19/2015 2:24am
Hi All , haven't been on in a while But, Traded the two bikes I had for a 97 Honda 2 stroke water cooled dirt bike that I know nothing about and don't believe anyone around here does either , Ant way This engine had been rebuilt then blew the head gasket scared the cyl. so with new Wiseco piston .080 over had it bored , they did nt cut the power bands back / the person working on it with me has some knowledge but does not seem to know how much to cut the power bans back or how to check them for rightness . Can some one please Help , My 16 yr. old is bitting my bit here is a pic of the bike I don't know what style the bike is and have some Goodies to put on it after we get this straightened out .
Sorry I don't have a better pic.
Edit: By the way, I'm digging the frame modification that was made to that '97. Lucky find.
Lot of good tips in this video , but ya scissors or a razor blade will make quick work of a powerband
Also as an FYI..........Talk about "Power Bands" will always get you a lot of Sarcasm as there is no such actual part.
backtire you need to confirm if it has a steel sleeve or not before you run it.
If you need to have your cylinder bored oversize, avoid the steel sleeves. Have it re-plated by a competent shop like Powerseal USA or Millenium Chrome.
If you already have a steel sleeve, make sure it has been honed to the correct size for the piston you are using. The clearance is a crucial measurement.
The shop that bored the cylinder should have done the work on the power-valves when they did the bore work. It will be obvious, they should not stick out into the cylinder bore.
Post a reply to: Cutting Power Bands
