FL
4/22/2016 6:03pm
I have a 2013 crf 450, has great compression. New top end with about 20 hours on it. Bike runs strong lots of power. But when I come in and shut the bike off sometimes ( not all the time) when I go to start the bike for another moto. The motor acts as if its seized. Kickstart is frozen. But if I take the bike off the stand and push it at a fast pace and bump it into gear, the kickstart is then free again and starts normal, Please help. Im petrified its the crank
Every time I have seen this in the past it was caused by a worn out cam chain that is causing a timing issue for the auto decompression device in the cam to work at the correct time.
When was the last time the cam chain was replaced?
I have seen this issue many times. I have also seen riders replace the OEM tensioner with aftermarket manual units when it was just a worn cam chain and then have major engine failures.
I am not telling you this is the only possibility, but the cam chain is a very neglected overlooked wear item.
I would also be looking at the valve clearances, timing and the auto decompression parts in the cam as possible issues, but I would replace the cam chain if the valve clearances are correct.
the pre-2008 Honda CRF450R's had a different style of a decompression unit that was an arm that require very precise adjustment to make it work correctly and many bikes suffered the same issue you are stating. IN those bikes the easiest fix was the proper setting of the auto decompression arm. The newer versions are operated by a pieces in the cam itself. If the cam timing or the exhaust valve clearances are not correct it will not work correctly.
If I recall correctly the recommended service limit of your cam chain is way under the 95 hours you have on the bike, but I could be wrong. I am thinking it is in the neighborhood of 60 hours.
Honda has also had issues with the new style being too aggressive and causing some stalling issues at low rpms and modifications have been made available to correct this issue.
Check out youtube.
Paw PAw
This can be caused by dirt, trash or wear. I would remove the cam and clean it to see if that fixes the issue at hand.
I can't tell from the photo, but the cam does seem to be fully seated in the bearing which could also cause a problem with the auto decompression's operation.
Post a reply to: 2013 CRF 450 motor problem HELP!
