4/7/2015 1:35pm
Hey everyone, a good friend of mine has a problem with his 2010 YZ250f. His throttle seems to lock/get stuck around half throttle, on with the bike on the stand you can twist the throttle 10 times and 1 in 10 times it will lock. It almost feels like something in the carb is becoming jammed leaving the throttle stuck open. We took off the throttle tube, and both cables and they all work freely and are in good shape. So its not the cables. We removed the small cover on the right side of the carb which reveals the "wheel" type thing where the two throttle cables connect to. We removed the cables from there and moved that wheel/pulley until we could feel the locking/seizing that was causing the problem, and sure enough the wheel/pulley locked on just opening and closing it. This was about as far as we got with getting into the carb. Has anyone else had this problem?? We are going to be removing the full carb and seeing what could be wrong, but I was hoping someone else might have had the same problem and be able to direct us in the right direction.
Please Help!
Thanks you
Please Help!
Thanks you
Post a reply to: 2010 YZ250f throttle becomes locked! Help!
