Aledo, IL
397th
2/13/2015 5:40am
I saw this post and got some good starting info:
http://www.vitalmx.com/forums/Moto-Related,20/2013-KTM-250-SX,1241842?p…
42 pilot
172-175 main
1.5 turns out on the air screw
3rd clip on a NECJ needle
My question is will this work at aprrox 700ft above sea level? I run good pump gas (93 octane), should I mix it 32:1 or 40:1?
The bike has FMF Fatty and FMF shorty.
Any help would be great!
42 pilot
172-175 main
50/50 gas at 44:1
165 main
stock needle 3rd clip
42 pilot
air screw 2 turns
Great plug readings and runs like a 2-stroke ought too. It will pull 3rd gear starts off concrete with stock gearing and revs to the moon.
I would go with Digger's advice. See if it can pull a 45 pilot and stay over 170 on the main. Can't help you with the finetuning because I'm at sea level, but you'll figure it out.
I did go a little bigger on the main on my TC and went with the RM Needle and a 45 pilot for most weather conditions.
Keep running your fuel at 32:1 Barnett. I have been running that ratio in KTM's for 10 years in 125s, 150s and 250s with zero problems. If it smokes a lot or gets very greasy at the exhaust tip try leaning it out to 40:1 but I suggest you start with 32:1 and see how it goes. I have zero woods experience so it might be a little rich.
Post a reply to: 13 KTM 250SX Jetting Help
