Colleyville, TX
4/18/2019 8:36pm
With the renewed interest in the YZ100's, I'm wondering if anyone has actually done the conversion of putting a 1982/83 IT175 cylinder on a 1982/83 YZ100 ?
I have spent time researching this online and have found some opinions that this can be done, but no one who has actually done it.
What I have learned so far is that an IT175 connecting rod would need to be used, but I have not found any information about fitting the 175 pipe and carb on the 100. I would assume for the "175" engine to run well, the 175 pipe and the larger 175 carb would absolutely be required.
Has any one attempted this conversion? Or have any other well informed information on doing this conversion?
Have you ridden the bike yet? Can you comment on just how much more/different the power is with this conversion?
Post some pics when you bring her home!
Yeah, the 175 conversion would disqualify it, I didn't know that. I thought it was "anything goes" based on the way some of those bikes looked at Don's this year.
The cylinder is maxed out, so I have been watching ebay for one, unsuccessfully. I guess I will have to send it out to get sleeved. Cooksey should be doing the crank next week, so progress is being made. Give me a call
Thanks in advance. Email is vetmotoxer34@yahoo.com
I finished the YZ100/175 conversion. This was the final result.
Greg
Did you use the 100 close ratio transmission?
Is that the IT175 pipe? with which DG silencer?
thanks
Your buddy Charlie hooked me up with modifying a 1985 IT200 pipe and silencer to fit my 100/175 conversion.
Man I've been away from Vital for a while. Glad I could be of help on your build! Your bike turned out great and from the reports I've heard from my TVRC buddies it rips. I'm glad you went to Charlie, he's the "man" with stuff like this. As you saw his work is better than the factory's !
It's only a 50/50 chance I can make DD this weekend, but if I do I'll try to find you.
Post a reply to: YZ100 - IT175 cylinder conversion
