- Pick trends
- Create a private league
- And more!
Use the hair product stuff and lather it on the tank real good, then wrap the tank in saran wrap and place it in direct sunlight for a couple hours. The sunlight part is critical, as the UV light creates a reaction with the solution that's on the tank. Let it sit in the sun for a few hours until the solution has dried.. wipe it clean, and repeat several times. Again, letting the solution dry on the tank in bright sunlight is important
But yeah hp and Uv light is the go to.
There are different concentrations of the salon formula.
In my experience, try very hard to have the thickness the same on the surface. If it varies much, it will leave areas looking less or more changed.
Look up "Retro-Brite".
EDIT: Also, I did not wipe it off, but rinsed it off outside.
I tried all the popular tricks and ended up ordering a blem tank from Clarke. I’m glad I did.
I did send off one of my white CR tanks to a restore guy. It wasn’t cheap at $165 I believe. But Clarke had no more blems.
I’m still waiting on my tank return coming on 2 months.
Even the tank restore guy said after his efforts it’s best to always empty the tank after wards. From my limited understanding you need to do this after restoring since they will return to yellow quickly if you leave fuel in.
I’m going to buy another Clarke for the restore I’m doing now.
I am looking into Vapor Blasting as an alternative. Hopefully using that can get rid of the debris and discoloring. Polishing out the plastic would be just slightly easier.
I tried the sanding out and discovered I do not possess the temperament for that either.
To this.....
I will be using him again on 2 other tanks and an airbox. Great work just give him the time. Roughly a month or so to get back.
$165.00 which includes return shipping.
For that tank pictured it was the way to go. I know that must have been a load of work. In fact I thought those spots went all the way through. Obviously not.
To get from one image to the other was at least 3 hours. Use wet sandpaper. Water helps the sandpaper work by washing away debris. I started with 360 and spent too much time. I went down to 220 and really started cutting through.
Just understand the heavier grit or lower number for the paper means fast cut but deeper scratches that will need to be removed.
I just started with 360 again.
For this box I ponied up close to $50 to buy a quart of some plastic primer. I will spray that and then Cerakote and off into the heat box.
I tried most of the known shortcuts already. None of those worked for me. To restore a tank it will all be about sanding. But at least you only need to concentrate on what shows.
Post a reply to: Restore White fuel tank
