Hi,
Hope someone can help - just restoring some old CZ’s and the tank color looks wrong, by any chance does any one know the original color code for the redishy / orange color?
Many thanks,
Russ
Hi,
Many thanks,
Russ
Edited Date/Time:
Joe used to do a lot of tank restoration. He may know. How about Dave Boydstun of AMS ? They may know.
https://www.facebook.com/groups/VintageMotocrossbuyersSellersGuide/?fref=nf
I have a can of the original color red for the twin pipe CZs. I was mixed for me about 3 years ago. Not sure how quick you are needing the info, but in a couple of weeks I could take it for a color analysis and send you the mixture.
I assume that paint stores can take a sample, scan it and get the mixture of colors.
There seemed to be two reds for the twin pipe. A semi-dark red and the orangish red. I have twin pipe tanks with both colors.
I think I also have the correct cream color for the fenders. I have several twin pipes in different stages of restoration.
Thank you for the replies!
Txjcfsf - Thank you for the offer but please don’t go to that much trouble, i’m sure I will be able to find the code..
If you or anyone knows volume of oil for the forks would also be very helpful - either capacity or measurement from stantion top..?
Also what would you use to seal the fiberglass tank?
Many thanks again
Regards
Russ
Edited Date/Time:
Many thanks again
Regards
Russ
HEW177:
If your Twinpipe CZ's forks are original you want to use 170cc of 20 wt fork oil in them.
