Pardeeville, WI
6/7/2015 6:58pm
1984 kx 250, I got this last fall. It did run but wouldnt rev out. I found the cases were leaking and figured that was the issue, nope... It has new stator, coil, sleeved jug and piston, also a keihin carb. What should my jetting be with this carb? The previous owner rode the bike with this setup but i dont really dont know what else to check. Any help appreciated. THANKS....Kevin
For jetting, try going up or down several sizes on the main to get an idea of where you're at. You aren't going to seize it from just a quick blast through 3rd gear to see if it cleans out and runs well.
If it's not running properly when the throttle is opened all the way up, the needle is not the correct jet to be worrying about. That's the main jet. Go pick up 150, 160, 180 & 190 mains. Try them all and keep in mind while testing that the main jet is a factor from 3/4 throttle and up. Yes, all the jets overlap a bit, but you're just trying to get it to run decent, not fine tune it.
The other the little keeper that goes over top of the needle that holds it in place in the slide was missing. Bike started and idled fine but when you opened it up it went all rich and bogged like crazy from then on. The needle was hanging open even when the slide was closed.
Oh yeah, had a CR85 cause considerable problems too. Owner had pulled the carb and it wouldn't run right after that. There was a little top hat looking brass piece that went in the carb before the venturi for the main/needle. That top hat had fallen out and was missing. Had to buy a new carb to figure that one out.
Matt Fisher... I just thought i would play with the needle setting because it ran well for the pevious owner
PN27416.... New Boysen reeds
I agree with Max- electrical.
On the bright side, I won the village idiot of the year award for my sufferings.
Try putting a timing light on it and check the timing. Make sure you can see the advance as you rev the beast.
Regards
https://www.rockymountainatvmc.com/oem-schematic/2
Have you ever put a timing light on the bike? It would eliminate the whole guessing game. Lining the marks is fine, but the timing light would tell you where it really is sparking. It also would allow you to see the advance is working properly.
Try to get a timing light on it and let us know what it shows.....
Cheapest ive found
This is 270
Most were 311
Seems its unique to the 85. Perhaps other years would work but are a different weight
Post a reply to: Got it going again, Same issue
