- Pick trends
- Create a private league
- And more!
OA Length:
pin width:
pin length:
gear width: ____ (gear tip to gear tip)... _____ laying flat against two gear tips
gear length:
gear pitch:
shaft width between gear and valve
shaft length (between gear and valve):
valve width:
valve length:
bottom pin width:
bottom pin length:
OA Length:
Also - would you be able to take a few photos of the KMX200 valve next to one of your KX125 valves from a few different angles? You can get a free image account at http://imgur.com or just upload them here on Vital (click Upload Photo when making a post).
pin width: .239
pin length: .590
gear width: _.554_ (gear tip to gear tip)... _.537_ laying flat against two gear tips
gear length: b4 .345 after grind .307
gear pitch: dunno? but fits standard idle gear
shaft width between gear and valve .287
shaft length (between gear and valve): .391
valve width: .767
valve length: .979
bottom pin width: .233
bottom pin length: .228
i didnt have much of an original valve to compare to, but i managed to get them to fit.
the kmx valves have the slots going the same angles, so i cut the corners off one to open the port up
Thanks again to KidKawie for help with my old valve earlier this year. Will hold on to it as a spare.
http://www.ebay.co.uk/itm/Kawasaki-KX-125-KX125-G1-1989-exhaust-r-h-pow…?
Kawasaki KX 125 - 1989
Kawasaki KX 250 - 1993
If you need power valve , Contact me at facebook : Papouch
Are you working on getting other powervalves like from the 86 / 87 KX125?
These worked for an '89 KX125 and can be made by any competent machine shop from commercially available materials....
Valves are 7075 aluminum and gear blanks are 1045 steel (both very strong). Gears are pinned to shafts.
'89 KX 125 Power valve drawings.....
Best of luck,
Steve
Steve
the idea is good
I've already tried it,
Unfortunately it does not work
joining iron and aluminum has weaknesses
still work on the tooth module
you do not get it right
it's no standard
this may work there
but not ideally
https://www.facebook.com/kxpowervalves/
As of Jan 2019 he wrote:
Welcome,
Why Powervalves for Kawasaki KX?
The answer is simple - they can no longer buy new ones, and buy used in good condition is very difficult.
I am currently producing Powervalve for:
KX 125 1988, 1989, 1990, 1991
Developments include:
KX 125-1987, 1992-93
KX 250 - 1990-1992, 1993-94
If you need others that are not on the list, write to me! I can produce them for you according to the original
Attached a few pictures of completed orders
Post a reply to: Custom machining an "obsolete/NLA" power valve?
